question about strut bars. HELP!!
for the front rear strut bar, should it fit with tension when you are putting on the bar?? or should it be more of a loose fit???
cause i bought one off ebay, and im trying to install it, but before i DO install them i want to know if it has to have tension when you put them on:bang:
It’s a ebay no name item, I dont think it matters.
j/k :slight_smile: It’s not supposed to be lose.
i wasnt sure if it had to be put on with pressure or not
thank you thank you thank you!!!
:dance:
Yeah the bracket on the ebay ones are made of like 1/8th in crap steel with tack welds :bang: . They are ok but with a little reinforcement would probably work alot better.
yea, I bought the eBay ones for the brackets then reinforced them and it works great
