Hello all. I was just curious what all it takes to swap a manual transmission into an automatic car?
I assume it takes the usual - transmission, flywheel, clutch set up, shift linkage, ecu, pedal set up, clutch cable, and shift rod. Is there anything i’m overlooking? I assume you can swap it with the motor in the car?
I found a 92 integra that is everything i’m looking for, the only downside is the fact that it is an automatic car - which i cannot stand.
Thanks, Matt
