Question on interchangability between Honda cars?
I know that a lot of things will interchange between honda’s and acura but has anyone made a detailed list. Its hard to find any Integra parts locally and there are plenty of honda civics in junkyards. I need to find a shifter linkage for my Teg. I’ve found various hondas and all the linkages look the same. So does anyone know of an interchangability between the brands thread?
Thanks
u could use another integra’s shift linkage 90+ some use gsr’s cuz its slightly thicker (i think).
i know that didn’t exactly answer ur question, but if u search “shift linkage” then you’ll find the answer you are looking for. i think an EF shift linkage would be close, but i doubt it would work. just find any da/db/dc shift linkage.
ITR shift linkage and STOCK ITR shifter.
Do not be a short shifter, do some reading and find out why they are bad.
[QUOTE=G2 Racer;1935405]ITR shift linkage and STOCK ITR shifter.
Do not be a short shifter, do some reading and find out why they are bad.[/QUOTE]
he wasn’t asking about a short shifter. he was trying to find a shift linkage that is compatible.
if you’re having trouble finding parts for your teg just get the part number from the ACURA dealer and see if they have it at HONDA.
The Honda dealers I know can’t help when it comes to Acura part numbers. They can get Acura parts but they have to contact an Acura dealer just like we do.
Problem fixed, I rebuilt the u-joint on the linkage. I posted the write up.
