Question on removing relays
I have removed my ABS due to having a broken modulator and I could not afford to replace it and also diagnose the rest of the problems with the system. But that aside, I am removing some things from the engine bay and would like to know what these three relays control and if any other crucial components run through the relays…
I circled each with a different color to avoid confusion as to which one is being specified
Any help would be much appreciated
The one you circled in green is the front fail safe relay,
blue is the ABS pump motor relay,
and the red one is rear fail-safe relay.
If you took the abs out take them out they are of no use anymore
