question regarding hydraulic clutch in GS-R transmission
I’m doing a B18C swap, with LSD transmission. The motor is NOT in the car yet, so this is why I’m asking now, instead of later. I will be using the Innovative Cable-to-Hydro conversion kit (the mechanical kit, not the full hydraulic conversion) and I have encountered what seems like it could be a major issue.
not sure what it’s called, (release fork, maybe?) but the lever that operates the clutch on the transmission (that protrudes out of the case) is doing something weird. When I removed the hydraulic setup, I checked the play on the lever, and when I push the lever back (as if I was depressing the clutch), it goes back fine, but doesn’t automatically retract back to the original position. Is this normal? I’d hate to be driving, push in the clutch, and when I let the clutch out, the clutch not engage due to the lever not coming back to its natural “resting” position.
Make sense? is this normal because the car isn’t under load or being driven? or is it faulty?
It’ll be fine. On our clutch cable all we really need to return it is the pressure from the pressure plate pushing back, and the spring on the clutch pedal. And when you try pushing on the release fork you will not be able to release the clutch by hand. I tried, asl your doing is moving the throw out bearing back and forth without actually pushing on the pressure plate. This is the slack that our clutch spring will pull back.
The return-spring (inside the trans, connected to the ‘tabs’ of the throwout bearing) should return the clutch fork to its resting position.
Yes it is pretty damn tough to compress the pressure plate by hand… but there is a bit of play in the fork before the bearing touches the pressure plate… if the clutch fork just ‘flops’ around, the spring may be broken or bad.
yeah, I had my dad check it out today, and he confirmed what you guys said earlier. it has a little slack, but we used a pry bar and some serious muscle, and it pushed back a bit. and it did instantly go back to its rest position.
Clutch = Fine :rockon:
thanks for the help, guys. I was up until 5am researching this information, worried that I was going to have to do more work and possibly spend more money.
