Question
I recently purchased a 92 LS and I am not that familiar with the tuners.
I have always had Muscle Cars.
I am new to this site and I hope to gain abundant knowledge from you guys.
With that being said, I was wondering if 17" rims 40mm bs with 205/40/17 tires will fit and not scrub if you do not lower the car?
Also, My AC is freezing up the condenser and it is thawing out in my floor leaving a large puddle of water there.
When it freezes up the AC it then starts blowing hot air.
Anyone have some advise on this issue ?
I have definately got to fix it !
http://forums.g2ic.com/announcement.php?f=29
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
