quick engine install/removal question
Ok, just wondering if it’s easier (or possible) to install the engine (b18a if it matters) with the manual tranny bolted up, or if I should do the engine and tranny separately, install the engine first, then put the tranny in? I took them out separately, but I’m thinking it might be easier to get them back in if I assemble them beforehand, but looking at the engine bay, I’m not 100% sure it’s either possible or easy(er). I do have an engine leveler hooked up, so I can adjust the angle of the engine while hoisting or lowering. Thanks for any input!
Put it all together before you put it in. Any b-series engine will fit into your engine bay from the top and since you have the leveler it will make it that much easier.
Later,
BR
ok, cool thanks! That’s what I’m gonna do then :slight_smile:
