I believe our stock wheel hub bore is 56.1mm so if I was to get rims that are 57.1mm, I’d just need a hubcentric ring to run them?
im not sure if they even have hubcentric rings for 1mm thickness
did you mean 67.1mm b/c i found those.
Well the guy that’s selling the rims said the hub bore for his rims is 57.1mm… so I was wondering if I can run those rims?
I found somewhere stating that our hub bore is 56.1mm… really not sure on that.
I just wanted to know if I can buy those rims and just slap it on… that’s all. They are BBS RA’s.
yup our hub bores are 56.1mm
i think the 1mm difference in hub diameter to wheel bore will be negligible.
some wheel shops even overbore 1mm over when a wheel bore needs to be enlarged.
So it should be ok for me to run those rims without any kind or rim adapters or whatever?
yup it shouldn’t be a problem as long as you’re using the correct lug nuts for the wheels you’ll be fine.
Cool thanks!
