quick question on Valve cover
when u want to paint ur valve cover is it necessary to have a new valve cover gasket… or can u use the same one and have no problem with it??
You can use the same one as long as yours is still in decent shape. However you’ll need too re-HondaBond the gasket at each of the flat areas that are near the 4 half circles for the cams on the gasket to prevent oil leaking.
where do i get this hondabond stuff? is it essentially just rtv sealant or should i definitely go with the honda product?
bump
Permatex makes a labeled equivalent if Hondabond can’t be found locally. Both are available online. As far as I know, it’s not just regular RTV.
Tom
hondabond can be bought at honda dealer for $6
you can just use gasket seal from auto zone or pepboys. it works the same, infact, it is the same…
