I am planning on putting in a new exedy organic clutch and lightened flywheel with a short shifter in the spring. I have never had a problem with the transmission grinding ever. I am wondering if putting in this higher performance clutch and flywheel will increase the chances that the tranny wiil start to grind. Should i replace the transmission fluid also?
Replace it GM Syncromesh FRICTION MODIFIED and hopefully it solve the grinding problem.
no. i have NEVER had grinding problems.
no, those parts should not cause it to grind. Yes, you’ll need to change the tranny fluid.
ok. thanks a lot. jsut the person i wanted to hear from! sorry if the question was stupid, im just learning about the mechanics of transmissions and clutches.
