Racing Harnesses Question
Need help installing some harnesses for my DA. I pretty much know where to mount the rears, but the side belts is whats concerning me. Need help please? Thanks!
normally the five point harness is attached one in front btw legs…drill hole and use bolt and washers; the two sides are repeated, drilled into unibody, bolts and washers, and the rears are bolted to the two back bolts under the seat. there is more than one way to skin a kitty though. the two sides can be bolted to the front seat bolts (much better) or even cage the car and weld tabs to the seat bars and then you are the safest and most reliable way (costed me a fortune!).
it is easiest to put seat in…fake put tabs and trial and error brackets, then remove seat and place tabs permenantly. jobs looks the best and is most trusting. do sit in the seat, slide it back and forth, and figure out the easiest and safest route. some ppl will want to move the seats back…well your gonna have to tighten the rear straps and loosen the front ones, and vise-versa. either way they are alot of work, so make them work hard for you. take your time and they will reward you.
Cool, thanks a lot!
