Rack adjustment wrench part #
I searched on this forum and the honda tech forum to find the part number for the adjustment wrench to loosen the 40mm rack n pinion lock nut. I found the part number and called honda, the part number that I found on these forums is wrong.
Here is the right honda part number for the wrench that you would need to adjust the rack n pinion tension: 07AAA-TL2A100 $35 w/ tax
I find a big pair of channel locks works just great and are already in my tool box, but good info :up:
info for people that want the right tool for the job.
I have the same tool, makes life easier :up: :up: for those that need this
I need it
i told you to use it when you were down here last time
archivethis
for the sake of preserving the part number.
