Rad slim fan
Just people’s experience on any brand slim fan , was looking at the blox one that’s 40$ but might go with a spal. When you installed the slim fan what did you do with the green and yellow plugs… ANd any of you that deleted AC what did you do with the yellow plug? Part of is goes to the cool side of the rad fan relay but is also part of ac wiring harness…
no idea what your talking about but installing slim fans is simple… its on par with changing your oil.
i use mishimoto fans. i have the shroud and an extra slim fan for my ac. when you actually get the fans in your hands and see just how easy it is.
These are the two plugs/ connectors the green goes to the rad fan and the other side goes to the rad fan relay… The yellow one connects somewhere in the ac harness and also to the cool side of the rad fan relay… Since I deleted my ac I don’t need it but now i believe my fan isn’t gonna come on… I don’t have plates for it as it’s not a DD but even when I leave it running for 20-30min the fan still doesn’t come on and it stays below half
If also asked multiple times about this yellow connector and no one has been able to help me … I’ve checked multiple manuals, multiple online databases (Mitchell , pro demand, all data) still doesn’t show up I believe it is connector c288 this is a 91 gs
if you pluged the rad fan back to normal it will work fine. its the ac fan that wont turn on anymore so you dont need it. i just cut the plug off my stock fan and spliced it in the slim fan wires so it plugs in like stock.
you need to find out how to wire it up so let the car warm up and see if it pulls or pushes air.
you spliced the green connectors wires for your slim fan? im pretty sure i got it all wired back up together correctly after removing my ac there were two spliced ground wires from the normal harness that went to power on the AC harness that i removed and, just grounded them out . if you dont mind, what kind of fan are you using?
