is it OK to wire up the radiator fan to stay on all the time (with the key) or will it cause the fan motor to burn up? any input is appreciated.
The rad fan was designed to turn on only when engine coolant temp exceeds about 190 degrees F, having it on all the time can prevent engine from reaching optimum running temp.
Why do you want it running all the time?94
thanks for your help. i was just curious because i had it jumpered to stay on all the time (for now) and i didn’t want the fan motor to burn up.
well my problem… my radiator fan is on like forever lol :werd: i dont know what to do anymore only thing i do now is take off the fuse under the left side of the dash :rockon: lol any help
That’s two treads you have jacked with the same problem, you should start your own tread. 94
mine doesnt’ come on AT ALL. I’ll start a thread.
