radiator fan runs way to much
I’m trying to figure out why my rad fan runs so much, my car can be off overnight and if i start it in the morning and let it run for a couple of seconds my fan will kick on and run for at least 20 minutes with the car completely cool, even just turning the accesory power on will kick the fan on when the car is cool, and if the car is warmed up it will run for almost a half hour after i shut the car off. It’s almost at the point where it’s gonna kill a less then year old battery.
MM&Y of car would help.
I assume we are talking about a G2, so the first thing I would check is the ECT switch, [rad fan switch].
Because it runs with engine off, [ign. off] I would check the Rad Fan Control Module and the oil temp switch. 94
Yeah it’s a 92 gs, i have access to a multimeter if that would help. Sucks trying to figure out why something works to much then not at all lol, could it be a short or something to cause this?
Yes it could be a short or something, I have to check something, will get back to you after lunch. 94
