radiator help
like a month a go i changed my radiator now i noticed that the tank reservoir gets empty pretty fast ,what could it be .thanks
maybe your radiator cap?
look for a leak. if you cant find a leak, then your most likely burning your coolant which would be caused by a blown headgasket.
yeah i think is dat cause when i turn the car on in the morning it sounds click click click clicking noise after it warms but after i drive it for a lil it goes away/
Check under the oil cap for milky brown color for blown head gasket.
Also white smoke when u have the car completely warm up.
Check and replace radiator cap if its been a long time and of not holding pressure.
Radiator can be clogged also. I used to have this problem when my shit keeps drying on me.
Best way to tell is get it pressure tested dont know how much for the parts or maybe a shop do it? This will tell you if u have a leak also and if its clogged it will read back different spec. Probably not flowing great.
I remember when this happens to me my water pump went soon.
alrite brothers thanks a lot
