waz up guys i have a 1992 Acura Integra ls and recently i noticed a lil tiny spot of coolant,well i left the car running put in park and i noticed that it was leaking from the bottom like from the radiator i couldnt seen where but it wasw from under the radiator also my reservoir tank its always getting empty …wat could it be …thanks guys
sorry to say this, but you posted in the wrong forum. try reposting in the stock engine section, i guess.
regarding your question, though, you may have cracked your radiator bottoming out somewhere or ripped a vein open somehow. I had the same problem and could have sworn that my radiator was dripping water. it ended up being the thermostat, lol.
well, this def aint electrical or entertainment related, but try filling up the resevoir and watching the radiator from above. fill it up, start the car, pop the hood and watch it. you could have some busted fins or maybe one of your hoses could be bad.
or you could try throwing in some radiator stop leak to see if that alleviates the problem. worst case scenario you need some new hoses, maybe a radiator
Probably the rad, replace it with an aftermarket one.
Check you bottom hose first, maybe you will get lucky and it will just need a new hose.94
