radiator problems
pleeze someone help me on this… arrite, today on the freeway i noticed my temp gadge went from normal to hot. it wasnt smoking or anything. so i pulled over and poped my hood and all this green fluid (i guess antifreeze or some sheit?? i dont kno) was all over the place. so checked around and on the radiator theres this little pipe that connects to this rubber hoes and that little pipe was busted. its like made out of cardboard or something… but yeah, i dont kno if you guys kno what im talking about, but i tried to explain this a guy at this car shop and he said i probably need a new radiator. fahhhk! and this had to happen before the weekend.
I highly doubt it’s the radiator. The only time you need to replace your rad is if it’s cracked somewhere. It sounds like you just need to replace that pipe.
You should consult a more reliable mechanic.
Regards,
Oz
thanx oZ… i think yer right, imma go check wit a different mechanic. that pipe looks replaceable to me.
latahz.
bboygoneracer: If you need a new radiator, member Lethal is selling his one-month old ALL-METAL rad. If you do indeed have to replace your rad, make sure you get an all-metal rad (OEM is part plastic which is inherently less reliable).
thanx guys… check it, my friend has a 92 GSR radiator. its in good condition and he said he’ll sell it to me for 50 bucks. do yall think i should get and would that radiator even fit into my 91 GS??? hit me back… peace.
