Check the fuses. I had the same problem and it was a fuse that kept blowing due to a POS phone charger. I wish i could give you the exact fuse number, but im at work so i cant really look. Hope it helps
It’s definitely just a fuse. Unfortunately until you nail down the issue they could keep blowing. Try disconnecting the radio before replacing the fuse, if you plug it and everything goes out then you know the radio is the problem.
