So, got my new Pioneer DEH-P5200HD yesterday but ran into power issue during the install. I twisted all my wires together to test the radio and make sure connections are good for speakers and what not before they are soldered. Well go to power it on and nothing… Bust out the old test light getting a constant power from the battery but no ignition hot. I check other wires thanking I may have the wrong one but I didn’t. I check the fuse, it’s good. then I check for power at the fuse and I get absolutely nothing. I assume the wire to the fuse box from the ignition switch is bad as the ignition switch was just replaced. Does anyone know what color the wire from the ignition to the fuse box is for the radio? Or what would be the best place to tap for an ignition hot…
Id swap the fuse just to be sure.
already have.
My 91 Integra manual shows a “WHT/RED” wire going from the ignition switch ACC position to fuse #22(10A) in the dash fuse box. The wire from the dash fuse box fuse #22 to the radio is “YEL/RED”. There is another fuse upstream of the ignition switch that if blown would not allow power to the radio. That fuse is #25(40A) and is also located in the dash fuse box. Hope this helps.
Thanks G4N1 I’ll check it out tomorrow!
