I had a new antenna mast installed into my car in October '09. Since then, my radio reception has slowly been getting fuzzy and now I am losing radio stations. I only have one radio station left that I like and can listen to, and it isn’t even my favorite station. What is going on?
Did you check to see if the antennae cable is still attached to the radio in the back? Maybe it came loose?
Wow what an easy fix. I found out that if my 10 disk cd player is turned on it kills the radio reception.
WTF? Why would you hook up the 10 disk cd player to turn on at the same time as the radio? It’s usually either or… I don’t quite understand your setup but glad you’ve found out the problem…
It sounds like the changer has a FM modulator.
Yep the cd player has that^
