Hello,
I know that the accessories are controlled/regulated by one component in the interior...but I don't know what that component is called. I've seen it mentioned around and I would like to replace it as it seems to be faulty in my vehicle.
Situation
Whenever I go less than 50 mph and go over a rough bump, the radio cuts out as if a breaker was tripped. However, the car functions as normal and using the power window controls do not cause the radio to shut off.
Whenever I accelerate past 50 MPH and maintain that speed, the car/radio is even more sensitive to bumps and shutting off. At this speed, the radio will also shut off if either of the power window controls are used.
History
The harness to the radio has been cut/hacked prior to my owning the vehicle. The prior owner had bare wires lying around in the deleted radio area. I added connectors to the ends of the wires in preparation of an aftermarket radio installation. I installed the aftermarket radio head-unit and everything worked fine for about 2 months. Then the “shutting off” issue started. I individually wrapped all of the connectors for each power and speaker line in electrical tape when I did the install. I wanted to ensure that there would be no “ground-out” issues.
After installing the radio, I noticed that the passenger door speaker does not work…or is not installed. I have yet to take apart the door to find out if the speaker is blown or if it is just bare wires lying around inside of there. If there are bare wires, would this cause the radio to shut off/ground out?
If anyone has any information on the component that needs to be replaced I would greatly appreciate it.
Thanks,
Dm of mD
