[QUOTE=Squeezethis;2039875]both of the previous 2 guys have methods that work. u could use the taped wrench/tools method to protect ur paint with whichever method/tool u use.
there’s a right tool for almost every job. and if there isn’t a right tool, then it means u haven’t made one yet.[/QUOTE]
Arr… Hmm well i dont have my car back yet to look at it, but i think removing the door checker pin might give a little added room. The problem I have, is that dumbass stock washer, is always to wide to fit back in between the fender and the edge of the door to line up with the hole correctly, if you get what im saying. Think im gonna go buy a allen headed bolt for that particular placing so i can use a long allen wrench and use the unbended end of it to tighten, and use a smaller washer on the bolt. Thatll prevent most anything i would assume.
Or can you even buy a allen head bolt with that threading
Edit: Looked up the size on acuraoemparts.com and its 6x16mm and did some searching
http://www.schnitzracingstore.com/catalogs/catalog.asp?prodid=326595&showprevnext=1
That would be the same stuff right? If so i think i might order a few to replace those bolts so ill never have to worry about it, im gonna be over protective when i get my car back from paint thats why im even posting this lol
Or also, since these are flat, may work out better
http://cometkartsales.com/store/chassis/cpa/metricbolts.htm
The first one in the list, the 6x12 ones, im sure 4 mm of length wouldnt effect it at all, would make it easier actually i would think.
Hm, the last ones linked from cometkartsales,
http://cometkartsales.com/store/wildkart/images/wkconwasher.jpg
Those, in silver or black along with the flat allen headed bolts would actually look nice for the 3 top ones inside the engine bay, may order 18 of the allens and 6 of the washers and replace them all llool $22 + shipping for 6 of the washers, and 18 of the allen bolts.
