random question
is there a way i can get both wheels spinning when im burning out with out lsd? only my passenger side wheel spins
How many time’s dose Mike have to tell you that this is not a help forum? And why the hell do you want to burn out for? Didn’t your last "burnout’’ thread get closed?
LOL I know both my wheels spin when i do one an i dont have a lsd the second wheel …an no I dont burn out all the time
I remember when I first swapped my B18C1 I took it out to a street race and went head up with an RSX after I launched everyone thought I had LSD cause both wheels hooked up evenly and left a pretty nice stretch of rubber behind. All I had was a stock YS1 LS tranny. As far as making it do it…IDK but I know its possible.
Use [SIZE=“2”]Soap or oil[/SIZE].:fingban: And from what Ive seen from all your posts,you’re car is not doing all that good.
http://g2ic.com/forums/showthread.php?t=202782
http://g2ic.com/forums/showthread.php?t=202584
http://g2ic.com/forums/showthread.php?t=202270
http://g2ic.com/forums/showthread.php?t=197033
http://g2ic.com/forums/showthread.php?t=202230
Apparently not enough.
That is why this is going to be big and bold.
http://www.g2ic.com/forums/announcement.php?f=2&a=13
[SIZE=“7”]POSTING IN THE CORRECT FORUMS
So you’ve run a search and didn’t find anything, so you need to post a new thread. G2IC forums contains A LOT of different boards. Each one has a description. If you need HELP with something, chances are you need to post in the ASSISTANCE section. ASKING IF A PARTICULAR PRODUCT IS GOOD SHOULD NOT BE POSTED IN ASSISTANCE, BUT RATHER IN THE PRODUCT REVIEWS FORUM. You may NOT post in the General Discussion forum (or any other wrong forum, depending on your subject) just because you think it will get more attention and you’ll get your answer sooner! Read each forum’s or category’s description to help you decide which forum you should post in. It’s a no brainer. If you post in the wrong forum, the thread WILL get (re)moved and you may lose track of it.
[/SIZE]
[SIZE=“7”]USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
[/SIZE]
