Rattle Is Driving Me Crazy
Their seems to be a sort of rattle under my car that is very annoying! I know it has to do with the heat shield but i dunno what to look for. Is it the big piece of metal above the piping? Because i also have this little piece of metal that is bolted under the pipe that was put in place of the resonator. If i remove these will it hurt anything cuz i dun wanna screw anything up!!
:argh:
There could be a heat shield riding on your exhaust making it rattle (the one above piping). If this is the case just bend it. Or the heat shield on your actual exhaust pipe could be a little loose. If you cant get the heat shield off just get one of those exhaust U bolts (with the piece of metal going from 1 side of the bolt to the other) and clamp that heat shield down. Maybe your exhaust is hitting your shifter (if you have a short shifter).
Ben
i dont have a short shifter and thanx for the help i think ill try both of them 2moro!
Peace
