I have a Tenzo R shifter, and after about 3000 rpms, it rattles making a very annoying noise. Would the shifter stabilizer bushings from energy suspension fix this? Anybody got the same problem?
-Timmy
-Timmy
I have the bushings and it still does the same thing
It is the shift linkage rattling on your exhaust. It is a very common problem for those of us with short shifters. I cut the counterweight off of the linkage and removed my catalytic converter heat shield to fix that problem. At times, mainly in the rain, it will still rattle a little bit though. You just get used to it.
You can put spacers in your rubber hangers to lower your exhaust too. That is probably my next step since I already have the spacers…
Later,
BR
