find something that fits.
if you dont have a huge screwdriver, just buy one.
[QUOTE=RukDa9;1698213]I replace the caliper that was stuck…Ok i bled the brake caliper i just replace and thats it since its the only one i had to disconnect the hose. Is that worng or do i have to bleed all the brakes now? Because now when i took it for a spin its harder to stop like i realliy have to push the pedal down hard to get it to stop? what do you think. :read:
:rockon: (thank you for the help guys)[/QUOTE]
if it consistently takes longer travel to stop then get it checked. Bleeding may help. Its normal for the first few engagements to be hard. Test drive it before really going out and driving it.
How far did you screw the piston back in? its only supposed to be enough to slide the caliper back on.
im having the same problem my rear calipers wont compress im gonna try the tool
