rear brembo calipers
Having a hell of a time finding a place that sales rear brembo calipers for the DAs. Anyone with info on where i can find a seller would be greatly appreciated!
Fast Brakes.
I don’t think they make the rears for the DA.
did you bother to look at fastbrakes.com?
http://fastbrakes.com/shop/product_info.php?cPath=28_44_126&products_id=405
[QUOTE=G2 Racer;1941383]did you bother to look at fastbrakes.com?
http://fastbrakes.com/shop/product_info.php?cPath=28_44_126&products_id=405[/QUOTE]
thank u sir!!! those say 94 to 2001 though. they will work on a DA?
ain’t that a bit overkill? not like its needed, unless u are just gettin them to have them.
Overkill is nice imo.
They will fit. You can also swap to a DC trailing arm, this is what I’m doing.
Did you bother to read what EXACTLY he asked for? He specifically asked for the BREMBO DA application. Hence the thread TITLE.
whats the point of that? just get some ES rear lower control arm bushing, or some aftermarket ones. switching to a stock dc trailing arm… i see that as basically R & R your current ones, unless the dc one has ES bushings or is SIGNIFICANTLY lighter.
Read the title on main page for the DA rear brake kits. Fits DC and [SIZE=“5”]DA[/SIZE]. They are the same.
http://fastbrakes.com/shop/index.php?cPath=28_44_126&osCsid=f64e89746f8bf928d11c654b287e34f7
1994-2001 Rear 2 piston kit w/11 inch rotors [SIZE=“7”]DA[/SIZE]/DC2Rear
I’m swapping to spherical bushings. No one makes them for the DA. Not mention they are easy to find then DA trailing arms around here.
[QUOTE=G2 Racer;1941862]Read the title on main page for the DA rear brake kits. Fits DC and [SIZE=“5”]DA[/SIZE]. They are the same.
I’m swapping to spherical bushings. No one makes them for the DA. Not mention they are easy to find then DA trailing arms around here.[/QUOTE]
Are you stuck on stupid? BREMBO and FASTBRAKE are 2 totally different companies. If that’s what he wanted all he had to do was say I want a rear break upgrade. I never said that they didn’t make rear upgrades for the DA. I was referring that [SIZE=“7”]BREMBO[/SIZE] does not make one for the DA
Not a bolt on one :nana:
Most times when I read brembo, I assume people are simply talking about any sort of aftermarket, non oem brake upgrade, like brembo or wilwood.
Fast brakes uses wilwood, not brembo but it works.
thx for the feed back guys!
I may have to go for the wilwoods. Only other question I have. What are the best bushings for our DAs?
