Rear Caliper Bracket Slide Piston Lubrication
For those of you that have never re-lubricated the slide pistons on the rear calipers, you’re in for a surprise. Unlike the front slide pistons, they don’t seal externally, they seal by inserting the end of the boot (a grommet-like end) into the piston shaft. This is a not really possible to do with the boot on the piston.
First carefully remove the boot and slide from the bracket. Don’t force it too much or you could rip the boot. After you remove it, clean out any debris and old lubricant from the shaft mating surface.
Then what you have to do is carefully remove the boot from the piston – you don’t want to rip it. If you do it will cost you $30 because you’ll need a reconditioning kit. Then cover the boot with a layer of Sil-Glyde or Permatex Brake Lube. Make sure the ends of the boot are thoroughly covered.
You can then simply press it into the shaft where it sort of pops in. Rotate it a few times to make sure its thoroughly mated in the shaft mating area. You can then clean and lube the piston itself and press it into the boot until it mates. Test the whole unit by pulling it out and away from the shaft to make sure the boot seals as it extends. This is critical.
For the whole process, here’s a great workup for someone in the Tegger forums.
http://www.tegger.com/hondafaq/rustybrakes/moredetail/brakes2_detail.html#squeak
