i have a 1992 acura integra and the camber in the back is not adjustable. the right rear was like -1.6 degrees and the left side was fine.
Ok… So what’s your question?
And what does left side is fine mean?
Does the left side have no negative camber? Could be a worn out bushing or a bent arm. I would inspect the bushings and get a camber kit to adjust. If its the upper arm a camber kit can fix that becaus3e it comes with new bushings. If its lower arm get a new control arm and that should help.
