i just bougt a 92 cx bubble i was wondering if the whole rear supension and brake will work from a da
thanks
thanks
the arms will swap.
keep the EG compensator arm.
E-brake cables may be a pain, i think use the EG cables.
i converted my VX hatch to rear discs from a 94 si. i swapped over the whole trailing arm assembly. the e brake cables were a pain in the a$$. i have been told you HAVE to use disc cables for the swap, the drum cables wont reach. also, the proportioning valve in the engine bay must be swapped over as well, to get the proper amount of fluid to the rear discs. i will have very soon, complete rear suspension/brake setup available off my 90 teg for sale.
