Rear driver turn signal
Having an issue where the rear driver’s side turn signal works properly maybe 40% of the time. The other 60%, it blinks super fast, as if the bulb is burnt out. Front still operates fine, just blinks fast when the rear doesn’t work. The bulb is good, and fuses seem to be fine (figure they are especially whereas it works 40% of the time). There’s no excessive power drain or anything that Im aware of (especially now since my audio gear was jacked on monday, but that’s another story. Fucking thieves). Any one have any ideas as to what it might be? Thinking a fault in the wiring, but i’m really hoping for something otherrwise…Anyone with any ideas?
I would check the bulb housing, make sure it is clean, free of oxidization/rust, make sure the bulb fits/locks securely in place.
Also check the ground and pos.(+) connections to the bulb holder.:cross: 94
