Does anyone know how to modify the current exhaust on the 90-93 integra. Instead of having the 90 degree muffler and the tailpipe running out the left side, how/where can I modify the hanger(s) so the exhaust/muffler runs straight out the right side from the axle?
I’ve seen this done on a few local cars. I’m sure any competent muffler shop can weld you a hanger on the passenger side.
Thanks SE-37K…now does anyone know any exhaust company which would make an exhaust system compatable with this setup or should I go with a custom setup and universal muffler?
Custom set up with a univeral(Walker Dynamax muffler). That’s my .02
Any setup that you can buy, hack, and reinstall to fit our cars will be expensive ($400+ new). I thought about using a second generation RX7 Apex N1 system once, but the cost is too high and many mufflershops won’t hack a kit.
You’re better off getting a universal muffler if you’re looking to do something like this.
Take ground clearance into consideration. I bought a factory test Prelude system from RS*R a long time ago only to learn that the muffler was too fat and unusable.
HTH
