I have H&R Sports w/ KYB GR-2s and the prodrive camber kit. I noticed some squeaking coming from what sounded like the right rear corner, and some WD-40 seems to have minimized it, but the right rear corner has about 1 finger more wheel gap. What could this be?
Check to see if the spring is seated in the upper rubber doughnut.
Yeah, it looked like it was in there correctly; I’ll double-check.
Re: rear fender gap - bigger on right?
Originally posted by BatNastard
…the right rear corner has about 1 finger more wheel gap. What could this be?
I had the same “problem” with every set of springs I’ve owned, including H&R Sports. The adjustable perche settings on my Koni yellows helped even out the drop.
i have the same problem with Nuespeed race w/ stock shocks
the rear right (pax side) is higher than the driver side.
but it isnt sitting properly in the base. ill fix it someday
Huh, so it sounds like it’s pretty common? Is it just the design of the car or does that side frequently come unseated? Also, would that cause some of the squeaking?
thanks a mil guys!
