Rear right window won't go up or down
Rear right window doesn’t work the switch and fuses seem to be good and window works when driver switch is used. What could be the problem?
How do you know the switch is good? Test it with voltmeter or something and it should tell you.
I tried the one from the other side which works fine
anyone know?
