rear seats
ive searched and havent found any pictures on how to remove the rear seats. any help would be apreciated, thanks.
Step 1- pull the latches and lay the seats down
step 2- pull the carpet back on the bottom half and you will find 6 bolts
step 3- start with removing the passager side of the seat(right side) and remove 4 bolts.
step 4- once that half of the seat is out remove the remainging two bolts and the black bolt on the side of the seat.
step 5- now the back half of your seats should be removed. theres one bolt that holds the bottom part on
step 6- there is 1 bolt in the center of the back half. remove it and your seetes will be out.
step 7- collect all your friends money that sat back there and have a party:rockon:
One more thing… when putting the seats back… make sure the clips (two clips on the cushion) on the seat (the part where you sit on) go into the hole before screwing the backend of the seat together or else you’re going to have a rattle when driving.
alright, thanks guys.
