rear suspension
i have a 1990 4 door and ive tried almost everything in my power to keep my teg running strong. Any type of preventive maintenence and ive done it. I’ve recently had the suspension tweaked. A couple of months ago i dropped the car using aerospeed coilovers/w stock struts. I got a loud clicking or popping noise from the rear suspension. I realizied my mistake and put some Koni yellow adj. struts all around coupled with Skunk2 coilovers. I had the work done at Kaos in Louisville and they replaced all the bushings that needed to be replaced and im still getting the noise? It’s not as bad ,but still troublesome. please enlighten me:cool:
well if the noise only happens when you turn than i’ts your axles that needs to be replaced.
its most likley the springs rubbing against the sleeves. Check the sleeves for wear
yup…either that or the collars on the coilovers r loose.
