Does anyone know if a rear sway bar from a Type R will fit my 92 GSR and does anyone know what the actual spring rates are for the 92 GSR ?
I am looking for a stock sized (same length) but stiffer rear spring, any ideas ?
Thanks
Sure here’s a link http://www.g2ic.com/forums/showthread.php?t=199427
^^ Great Source ![]()
http://www.g2ic.com/forums/showthread.php?t=183413
A type R sway bolts directly to the rear subframe. You’ll need the swaybar brackets, some long, strong bolts, and custom spacers as outlined in the how to.
Stiffer springs should be mated with stiffer shocks, else your controllability on rough surfaces will be less. Are you trying to work around a racing rule that requires stock springs?
Yes, I am bound by the rules to retain the stock springs for this particular class, but if and when I move up to a class that allows these type of modifications I want to have the knowledge that a Type R rear bar will in fact bolt in with whatever mods are required, so Thanks for that information. I am still wondering what the actual front and rear stock spring rates are so I can have an idea how much more aggressive I should go with stiffer springs that would retain a near stock ride height (in the interest of maximum wheel travel for my particular motorsport event) BTW I have already installed Tokico Illumina 5 way adjustable shocks so I should have decent wheel movement control already if in fact I do go to stiffer springs.
Thanks again for your suggestions and comments
The typeR bar is about 8 times stiffer than stock due to its bigger diameter and its different mounting point to the chassis. There is also the ST swaybar that uses the OEM mount point and is only 2.5 time stiffer. For more shock motion range look into ground control top hats, they move the top hat about 3/4 inch higher for that much more shock travel.
Answered one of my own questions so if anyone else wants to know, the spring rates for a stock 1992 GSR are 263lb/in at the front and 143lb/in on the rear, pretty sad for any performance work. At least I know now. Is this “ST” rear bar a factory item or an aftermarket piece ?
Aftermarket
http://www.summitracing.com/parts/STQ-51135/
