rear sway bar questions
so i have an extra (stock) rear sway bar for a da integra. i just finished repainting it and i would like to get new bushings for it but im not sure as to what the stock size is on those bushings. energy suspension offers alot of different sized bushings for the rear sway bar. also im going to be buying front sway bar endlinks from energy suspension as well… id like to know if anyone else has thease installed on their da and does it make a difference in ride or handling?
stock is 14.7mm for coupe 15.9 for sedan. http://ef-honda.com/ben/EFhybridsus.php in the sway bar section. thanks to Ben for that article
the endlinks only make a noticable difference if the ones its replacing are worn.
well… the smallest size rear sway bar bushing that energy suspension makes is 15mm. will that work??
