Rear trailing arm bush busted :((
g’day guys just a question if what other honda model’s i could put and fit perfect in my da integra rear trailing arm bush cause i’ve tried searching for da integra rear trailing arm energy suspension bush and none was to be found, im located in Australia.
help guys
thanks :slight_smile:
i could be wrong… but…
http://www.energysuspensionparts.com/proddetail.asp?prod=16.7107
and its a bushING btw… if you search for a bush you may find this
or the lower parts of an old man
yeah i’ve seen this type of bush it’s a good bush makes your pee smell like nature when you urinate on it
i believe the 94-01 integra trailing arm is a direct swap
can you confirm that? or anyone else?
thanks
cross reference part numbers bro… use the energy link i gave you and see if the part numbers for the bushing are the same for the dc. if they are then it would be safe to assume that they are the same from honda as well…
I think he meant the whole trailing arm. The bushings themselves are different but the actual arms are interchangeable. I would just order a ES,OEM Honda or another aftermarket bushing and change it out. I know ES makes DA specific bushings because I have them on my car.
yea i’m talking about the trailing arm, not the bushings
I have some 96spec itr trailing arms on my 91. so confirmed.
Why replace the whole arm instead of just the bushing? It’s super easy.
The bushing size is unique to the second Gen integra but the replacement is straight forward. I would go OEM or Hard Race if it were myself , the part number for the OEM integra bushings is 52385-SK7-N02. I recently replaced mine with OEM bushings but I can attest to how stiff the Hard Race RTA bushings are as my friend just got a set for his DC2.
isn’t that more expensive? plus your getting a second hand
thanks guys yeah i want a performance one i’ll look into that Hard Race RTA bushing.
