reccomended affordable replacement distributor cap?
upon inspection of mine, the gasket is gone, holes are cracked from over tightening.
rotor was loose/wobbly. screw on the rotor wasn’t even finger tight and half out/in.
the 4 posts inside the distributor were beat up and worn half through.
everything else looked good, near new condition, even the rotor and inside wires.
so i want to replace the cap due to the uneven wear on the posts inside from the wobbly rotor.
local parts stores have an assortment, from $10 for Bosch all the way up.
I’m NOT buying msd or one of those clear caps. just want a basic black or blue oem style cap.
opinions on brands? already running blue NGK wires and NGK plugs.
Best to go with OEM for the distributor cap. Others will no doubt agree. I asked this same type of question last year, and the consensus was OEM. I don’t have any experience with non-OEM brands. Maybe others do.
