http://www.youtube.com/watch?v=xjBZWg9JKxs
Heres a link to couple passes at a recent test and tune.
car went 12.3 @ 113mph all motor.
wow thats awesome!! what is your setup? looks like your car really picks up on the top end
nice i see its a gsr
nice run!! how come on that last run you went to 5th? what tranny setup are you running?
weight?
motor?
suspension?
:rockon:
weight? 2180 with driver
motor? B20vtec / 215whp
suspension? pic 14k front / 18k rear.
i shift 5th anything over 110mph, YS1 Cable tranny with welded diff.
Nice! I gotta say, even with a horribly late reaction you still ran 12.3’s
again…reaction times have NOTHING to do with your actual time.
^ this is true, your better of taking your time on the launch.
are you on stock sleeved b20v? how the heck did you get your car to 2100 lbs…
i think i’m going to jump on the PIC setup too, are you running the apex or select? do you street drive on the 18k rear?
wheel diameter?
What cams are you running?
Stock sleeve 84.5mm bore.
Pic select, 18k rear they ride smooth as long as you dont slam the car and you can turn down the stiffness as well.
22x8x15 slicks.
Skunk Stage 3 cams.
2180lbs with driver. power windows, power mirror, sunroof still all work.
just did litter stuff here and their, plexi rear window, no wiper motors, no passenger seat, etc etc
thats really good. i’m wondering if CDN tegs are natually lighter than the USDM ones
what type of pistons and compression do you have? i’ve been hesitant to run 84.5 on fear the sleeves will crack…
what rpm are you spinning to?
11.8 compression wisco pistons, stock crank.
can rev to 9000rpms all day no issues even higher if i wish but it would make no sense
[QUOTE=plzbeleiveit;1938772]Stock sleeve 84.5mm bore.
22x8x15 slicks.
Skunk Stage 3 cams.
just did litter stuff here and their, plexi rear window, no wiper motors, no passenger seat, etc etc[/QUOTE]
where did you get the plexi window?
flex-a-light
