well just as it says my e-brake light comes on when i turn and i havent a clue why. It has always done it in this car i think haha … so i went ahead and changed the rotors and pads all the way around … made sure my e-brake was adjusted good and everything thought it stopped but then i noticed it again … anyone have a clue what could cause this ? its a red 91 GS
oh well then ur screwed. lol. it sounds like something electrical. check ur grounds
Check your brake fluid level and/or the brake fluid level switch.:whisper: 94
lol i know its a red GS iam screwed lol … anyways alright will do any other suggestions? possibly a bad/dirty sensor?
dont know where the brake fluid level switch is i think i do but am not sure
It is part of the lid of the brake fluid reservoir. 94
Would almost gaurantee it is fluid level but if you just replaced the pads you would have vised the brake actuator in and raised the fluid level. Is it not coming on as often since you did your pads e.g. only when you turn really sharp now?
i know i know i solved it lol i feel like an idiot … some how my brake fluid got low i normally check on an every other day basis check my oil and all other fluids and such i had a loose connector on the brake line
