How do you reduce the understeer? is it possible?
Some searching should turn up a lot of info, but basically, stiffer rear sway bar and stiffer springs in the rear can help reduce understeer. I’m not a suspension expert though, so search some and you should find some pretty good, detailed answers.
http://www.g2ic.com/forums/showthread.php?s=&threadid=40154
http://www.g2ic.com/forums/showthread.php?s=&threadid=26912
http://www.g2ic.com/forums/showthread.php?s=&threadid=39492
http://www.g2ic.com/forums/showthread.php?s=&threadid=38593
http://www.g2ic.com/forums/showthread.php?s=&threadid=37434
Thanks! ![]()
