Ok i have everything that i Need for the install but i dont know wher the OEM USDM realy is located so I can put the JDM one in its place…please help…pics would be nice but not nessecary…thanks…I have a DB1 if that helps i dont know if its differnt from the DA
There is no oem relay. You wire the jdm one in. 5 wires: Power, Ground, Signal from switch, L/R Mirror, L/R Mirror.
This should help you out a lot http://www.geocities.com/dwnlow91/JDMmirror.html It does kinda leave some stuff out, like there is no oem relay to replace.
