Relocate license plate
For you guys in states that require a front license plate, have any of you relocated it to another part of the bumper? If so, how? I know I’ve seen a few pictures of it but I can’t seem to find them now.
Here’s a kit made by CUSCO, but I can’t see how exactly it works. Is this the only method?
http://www.optionsauto.com/prodinfo.asp?number=CUS-319550L
I’d hate to have to drill into my bumper, which it looks like these kits require.
zip ties
I drilled one small hole into the grill of my 90-91 style front bumper then used a long zip tie to go across the plate and the grill so it can be tucked right up in the corner. I’ll try to get a pic of what it looks like. Those relocation kits seem like way more work than its worth to me…
Those relocation kits are a waste of money. Just go to Home Depot and buy a bracket the length of your license plate, 4 bolts, washer and nuts, then drill four holes (2 for bumper mount, 2 for plate to bracket) and you’re done.
i just used L brackets. One end between the lip and bumper. (using the lip mounting screws) and the other end of the L brackets holding the license plate.
Password JDM makes one, but it looks like the same thing. I would think with any of the relocation brackets you’re gonna have to drill your bumper.
PWJDM
Here in Texas we are supposed to have plates on front as well, I haven’t been bugged for it yet as my front bumper was shaved smooth, I have mine on the dashboard right now haven’t gotten around to figure a mount yet.
Anyways I have actually seen a number of cars with the plate mounted in the top right corner(left side from front of car) mounted on the sun visor, don’t know how legal/passable this is but something I have been seeing around.
currently mine is mounted directly to the bumper with some coarse thread screws, the holes were already there as the bumper mounting ones have broken bolts in them…
however i was thinking about it after looking, mine still has the OEM lower bracket for the bottom two holes its a little bent but why not just mount the top holes to this right in the center of the grill? or move that bracket to one side or the other i haven’t looked at how it mounts under the bumper yet.
i’ll address it when i go to put my new 92-93 bumper on cause i’m sure as hell not gonna screw through a new bumper.
This is the one I have it works great… Works just like the Password JDM one and Cusco one. Yes you do have to drill holes.
http://www.streetlightz.com/License-Plate-Relocator-Black-P241C393.aspx
Heres what my looked like with it on
mine relocated.
using this kit:
http://cgi.ebay.com/ebaymotors/JDM-License-Plate-Relocator-1989-1993-Integra-DA_W0QQcmdZViewItemQQhashZitem2a057221e5QQitemZ180479992293QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
only difference with mine is that the bracket is silver in color, not black.
any kit you buy will require drilling. but, the upside is that the place you have to drill is on the underside part of the top of the grill, so even if you took your plate/bracket off, its not easily noticeable. took me LITERALLY 2 minutes from beginning to end. you MIGHT be able to get away with using some really durable double sided tape, if you’re 100% against drilling, but I would personally wanna take the chance of it falling off and running the risk of running it over. or worse, it getting flung into traffic and getting someone hurt.
if only we had skinny plates like in europe.
leave it to america to do things different
Thanks for the input everyone. I was envisioning some sort of “clamping” kit that is secured over the ribs of the front bumper so nothing has to get drilled. I guess it’s something I can make too but I’m not sure how difficult it would be to design it, or whether the ribs can even support such a design.
Yeah I relocated mine to inside of my car…right under the driver seat :smiley:
I used the 90-91 front DA bracket for a relocator to right below my stock 92-93 mounting holes. It made the plate look like it was floating in the middle of the bumper. This required no drilling.
this is the part number (71106-SK7-A00) and it goes for $4 from here: http://www.hondapartsunlimited.com/index.php?p=page&page_id=productdisplay&inputstate=5&make=Acura&model=INTEGRA&year=1991&version=3DR%20GS&transmission=KA4AT&section=INTERIOR%20/%20BUMPER&components=BUMPER&submit=submit
[QUOTE=ls/vtecstitch;2131631]I used the 90-91 front DA bracket for a relocator to right below my stock 92-93 mounting holes. It made the plate look like it was floating in the middle of the bumper. This required no drilling.
this is the part number (71106-SK7-A00) and it goes for $4 from here: http://www.hondapartsunlimited.com/index.php?p=page&page_id=productdisplay&inputstate=5&make=Acura&model=INTEGRA&year=1991&version=3DR%20GS&transmission=KA4AT&section=INTERIOR%20/%20BUMPER&components=BUMPER&submit=submit[/QUOTE]
Any pics?
mine used to be in my tool box but after a bunch of corvette customers came into the dealership needing to order the corvette brackets because cops gave them fixit tickets i put mine back on. i have put it on the driverside using some ebay brand one(cusco copy), 2 screws that go into the bumper. FYI the real cusco one is not a direct fit for our license plates, you have to widen the holes or drill new holes something like that.
my car originally came with the one like ls/vtechstich has but i did not like how flimsy it was, how much it stuck out and its position covering tons of space in front of my radiator and steering cooler…
i’ve grown tired of mine and have thought about getting this style http://www.f1spec.com/jdmliplbrbyz.html
i think i have something to solve this gonna look through the shop 2morrow, some small U shaped clamps and an L bracket on each one should work just fine, i’ll post some pics if i can find the clamps
Now thats a good Idea. did you make a way to mount the bottom. or just hang it from the top holes?
I’m actually thinking that little bracket is worse because it’s actually fully in front of the bumper grill. At least by using the holes in the black molding area of the bumper about 1/3 of the plate’s area is on the bumper and not blocking air flow :shrug:
Or can that bracket be used so that it’s shoved to one side? I don’t really know how it’s attaching to the bumper.
You can use the upper side corners of the grill area to mount that bracket too. Thats how I had it before I took it off for good.
Ah understood. Thanks! :up:
