i have a gs model teg with teh stupid a.b.s system but i want to remove it if any of you know how please reply thanks
abs
i heard a rumor that if u pull up on your e-brake and drive forward about 20 feet the abs will disengage and wont rengage till u turn off the car and start it again
that isnt the answer i was looking for im looking for how to take out the a.b.s system and put it back to standard rs model brakes with no a.b.s
did you try doing a search? it seems to me someone put up instructions a few months ago for this. I’d like to do it too, but there are other things taking priority over it at the moment ![]()
And for those just looking to disable it? There are 3 fuses in the engine bay fuse box that you can remove to disable the ABS. Much easier than playing with your ebrake every time you start up your car.
brakes
why do u wanna take out your abs any way?:shy:
its difficult. not for the novice or even semi hobbyist. and if you cant even find it on this board, you rank in there and shouldnt try or worry about it =P yes i have it too. yes i want it gone but im lazy and i suck
