i know this has probably been asked before, and i know ive read how to do it somewhere on here
but for the life of me i cant find it xD
the only articles are on 91-93 tegs and mines a 90
ALL the stupid lights are on when im driving and it looks so stupid in the day time… not to mention a waste of bulb life
how do i disable the drl guys
Your DRL is on the passenger side foot well. It is behind the piece of plastic that sort of starts in the door well at the front, and goes over the carpet. Just remove that and your DRL is sitting right there attached with a 10 or 12mm bolt. i believe the 90 is gray instead of black but I can’t remember for sure. Just unscrew it, then detach the electrical connector.
wow daytime running lights on a da? mine doesnt have that lol its a 91 rs
If I recall correctly they’re on Canadian models, not US-spec models.
in case anyone ends up looking for the same answer i was here
there’s two plugs going into the drl module
if you unplug the yellow one it will disable all ability to use any lights except headlights
the gray plug is the correct one to remove it disables the drl and still allows you to use your lights when you turn them on
