I currently have a 91 Integra with a b18a1 engine. I was looking to remove the a/c unit, and I was curious if I have to buy a new radiator to make up for having less hoses? Or, am I able to cap off the parts of the radiator that go to the A/C/ unit? Thanks a bunch!
I currently have a 91 Integra with a b18a1 engine. I was looking to remove the a/c unit, and I was curious if I have to buy a new radiator to make up for having less hoses? Or, am I able to cap off the parts of the radiator that go to the A/C/ unit? Thanks a bunch![/QUOTE]
Your thinking of the ac condenser that looks like a radiator. Yup you need to pull that out to.
The front bumper also so you can pull out hard lines. Might as well do the power steering. Oh and don’t cut any plugs left after everything is done. Just wrap them in plastic bag and zip tie.
Sounds good. I’ve been reading a lot about the a/c unit being removed, and I am not going for hp but a cleaner look. I only drive this car to work and back, and I am tired of seeing all of these extra lines. I want a cleaner look under my hood.
you know there are other options than removing it completely… you can make custom lines, tuck them, and keep the ac. its what im doing. i think keeping it with a clean and custom set up is cleaner than removing it completley…
[QUOTE=DA_all_day;2314654]you know there are other options than removing it completely… you can make custom lines, tuck them, and keep the ac. its what im doing. i think keeping it with a clean and custom set up is cleaner than removing it completley…
my opinion[/QUOTE]
could you upload a pic, so I can see how you are doing it? This seems interesting!
