Ok so I was wondering how to correctly remove the rear corner window
on the side of the back seats.
Is there a proper way to doing this?
Thanks!
(Need to know by morning)
Thanks!
to remove the window im pretty sure you have to cut it out. after you remove all the trim pieces.
yea those are glued in :down:
Oh well, Guess we’ll see how it works out.
I have a drywall saw maybe that will get in there. (the hand held)
idk. lol
Well thanks for the help.
I’ll just wing it as im trying to get it. lol
careful not to crack the glass!! its held in with urethane.
I used a piece of the truck release cable that I cut and striped down to the cable. but piano wire would be better.
you got to take a razor and cut out a portion of the sealant to get the wire thru, then Its just a matter of getting a friend to help to use the cable in a sawing motion. make sure to keep the cable pulled to the center of the window to minimize damage to the paint and metal. that cable will chew it up pretty good and obviusly the trim needs to be removed from the inside and outside of the car:)
I Think I have a drivers side one ill let go for cheap if your interested. just needs new clips.
How cheap?
I dont need it, someone I know needs it and is trading some subs.
Yeah I tried to get it but i couldnt, I had a pocket knife and it wasnt going
too much.
I can see using some wire would make it easy.
How much shipped to 37174? for the dirver side corner window.
Thats the one I want. Does it have tint?
Its not tinted, but it has a g2ic sticker on it:P
Whats your email? we dont want to make this a for sale thread
Ill send you an email with a couple pics in a little bit when I get off work;)
and yes, I would think some guitar strings would work
opon closer inspection and thought, its the passenger side I still have. I already sold the drivers side:(
sorry mang.
remember, when your sawing there a 2 points on the front side and 5points on the top side and where it starts to move downward and back foward, where it might fell like its hanging up, those are just the clips, just keep on it and they give. I would recomend having a couple of spare cables as well.
hears a picure of the window removed with where the clips are.
Yeah I noticed the clips today when I took off all the trim.
NP, I’ll try again next time i’m there. (its a junkyard)
I’ll be doing it myself so I’ll figure something out.
I dont see how its gonna be done with one person, but good luck with that
lol Just got word I dont need the window anymore so im all good.
Mods may delete
No no!
glad you did not delete. i searched and this is what i found… i mean i can get a side glass for 13 bucks but how hard is it going to be to take it out… you really need 2 PEOPLE???
a second pair of hand helps immensly, but I guess is not neccisary:shrug:
i got glass already pulled u give me $80 plus shippin ill send it so u dont have to deal wit that bs
